...and you should get a buzzer warning anyway...unless the door microswitch is faulty.
PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
If you unlock the doors and don't open any of them, the car automatically relocks itself, after about 30 seconds I think. If you want to leave the windows open a bit when you park, press the button to lock the doors, wait for the window(s) to just about be closed and then press the unlock button again. This will stop the windows closing, then wait for the doors to auto relock and the alarm should arm itself again.
SneakyMy postcode for delivered beer is 6152
Mk IV Golf has a 2 button remote, no centre button for the boot/hatch since there's no release inside for it.
'04 BMP MkIV R32 #144
search getnew
True, I just meant it was 2 button by default. Would that still work though to isolate the hatch lock from the doors? I haven't done the driver's door only mod, auto lock at 30km/h is fine & I can lock everything once inside the car anyway.
I still want distance to empty though, requires a bit more trickery unfortunately. And the cruise control light has never been enabled in the cluster either.
search getnew
Hatch still locks and unlocks normally with the normal Lock and Unlock buttons (as long as keyhole is set for that)
This extra button just lets you unlock the hatch separately.
You can isolate the hatch by moving the keyhole to a different position and then it wont unlock at all with remote.
The cruise control light is activated by changing a code in the engine ECU with VAGCOM - some cars don't have the facility though - depends on which ECU version you have.
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff| Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
2004 V5 Bora ~ Eibach Pro + Bilstein B8 ~ Tyrol Brake Upgrade
MY15 Golf Wagon Comfortline
Any IMMO 3 dash can have DTE if you wish.
and quick way to check if you have immo 3 dash is if the car and key simble when you turn on the ignition (for immobiliser) is on the right side (speedo), then you have immo 3, and if it's on the left side (in the tacho), then you have immo 2
unfortunately i found out i have immo 3 on the weekend, so my ecu swap did NOT go to plan... (immo 2 requires no codes for swapping ecu's, immo 3 does)
haha, not quite, you need to code the ecu or one of the controllers so that the key fob actually controlls the windows. it might already be coded on the R32, or perhaps someone has already done that mod for you?
but a good tip none the less. just not usefull to me yet!
