Cracked Pcv hoses near the intake mani are a common issue on your car from what I've seen. If you can't find much on here, check the 1.8t section on vortex.
Its a pressure actuator , requires pressure to open wastegate . If you crimp the hose you should be able to overboost the turbo .
---------- Post added at 01:53 PM ---------- Previous post was at 01:52 PM ----------
Doesnt really work on DBC turbo VAG cars , works alot better on DBW cars in diagnosing MAF issues
---------- Post added at 01:55 PM ---------- Previous post was at 01:53 PM ----------
That hose is a common problem now . It splits causing air leaks/boost leaks . Its not cheap to fix about $80 from a dealer
---------- Post added at 01:56 PM ---------- Previous post was at 01:55 PM ----------
KO3 runs a sleeve not a bearing
Bug_racer supports the rebellion of the euro revolution
Cool ill look into these things, another thing I've noticed is I'm not getting the same dv sound anymore if any sound at all, could this also cause this spool noise, it's a Apr r1 dv and is meant to be matinance free. I'll recherche k and try my old dv tonight to check its a dual port so I should be able to hear it release presure.
I've replaced and triple checked all hoses from and to the turbo.
Also does anyone know the part number for that cracked hose?
Also I do have 21hg of vac once the car is warm at start up its 18hg
Sent from my GT-I9100
The daily
White 2001 Mk4 GTI
GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
The daily
White 2001 Mk4 GTI
check the oil feed pipe for blockage. remove and inspect its worth the check for peice of mind. if there blocked no oil to turbo and they will squeal untill they seize!!!
The pipe should come off your oil filter housing and then down to your turbo. Full oil change should not be required you may lose only small amount of oil while inspecting.
Here is a sound clip of the sound at 2 seconds in it can be heard, has anyone had this happen on their car and what was the problem.
OK thanks grtuned, I didnt get time to look at it last night, hopefully tonight, I went back over the vac lines and found one that had split that goes to the DV so replaced that went for a drive still no DV noise.
Cheers again for the help.
The daily
White 2001 Mk4 GTI
Well I've fixed the noise for the moment.
First I replaced all the vac lines with fuel line and screw type hose clamps, dv working as it should again.
Second I made a new pipe to replace the split one, check it out, its temporary for now, bursons didn't have any brass right angle hose joiners, so I've made do with this.
When I get a new pcv valve ill remake it again.
Cars booked in for Monday to get scanned and a few things looked at but at least for now the noise is gone.
The daily
White 2001 Mk4 GTI
good to hear mate. nothing worse than the tiny little unseen problems that are a pain in the arse to even find.
