Results 1 to 7 of 7
Thread: Should control arms flex this much?
    Dec 2006
    Yay or Nay ???
    -DIDZ
    Nov 2006
    Largs Bay, S.A.
    It looks kind of similar to the flex I had when I checked mine a while back ... Even with the TT bushings rather than the standard bushings the flex is quite pronounced. If I get a chance I'll grab a pic for comparison tomorrow.
    Dec 2006
    cheers mate. Got a feeling it's messing with my steering quite a bit
    -DIDZ
    Aug 2006
    my control arm snapped just before where bushing part!
    Nov 2006
    Largs Bay, S.A.
    Here's mine as a basis for comparison ... I'm on level ground and the camera is being held close to perpendicular to the control arm. Have you replaced the bushings recently?
    Aug 2009
    are you guys low? mine look fine but they angle up (lowered about 50mm) and i do understand that this counteracts handling propertie??
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    Nov 2006
    Largs Bay, S.A.
    I'm lowered more than standard, but not massively low ... Not really much of an angle when I look at the control arm. I can see how it would angle upwards if you were lowered by a lot.
    Are you lowered by much Didz? Also, when was the last time your wheels were aligned? Have you hit anything recently? Tyre pressures ... etc.
