Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Running Problem, Loss in power, Rough idle, Shaking etc...
    Jul 2011
    Southport, Gold Coast
    [VIDEO]Running Problem, Loss in power, Rough idle, Shaking etc...
    hi all
    im in my first vw which is a golf 1.8t gti and i love it so far.
    but at the moment its hit a few a bump along the road (not literally)
    first im experiencing a weird shaking rough idle and 900-1000rpm, the front end literally shakes the whole car
    second is that when i drive i can feel it is kinda being restricted at 2000rpm can feel the lack of power
    and the vibration caused from this, but it would eventually shoot up after maybe 3000~3500rpm onwards to normal
    The annoying problem is this happens randomly, it kinda comes and goes. so i didnt thought much of it
    My primary suspicion is the MAF caz it looked rather 'not new' last time i pulled it out.
    My car is only running a *DRY* pod filter with the airbox ripped out.
    thanks
    VW Mk4 GTI 1.8t running problem - YouTube
    NOTE: In the video, car is driving fine UNTILL 1:07 it starts behaving very rough like i have described, then at 2:33 the car drove abnormally faster just briefly, than back to running like crap
    ---------- Post added at 10:42 PM ---------- Previous post was at 10:30 PM ----------
    and the sound of it on idle
    VW MK4 GTI 1.8t Idling Problem - YouTube
    D:
    edit 26/7/2012
    unfortunately im back to square one
    Aug 2007
    Perth, Australia
    get rid of he POD filter and replace the MAF. I killed my MAF when i had the POD filter, they dont like the oil from the filters
    Have you tried unplugging the MAF while the engine is running? It should run rougher with MAF unplugged. If nothing changes the MAF is def dead.
    Or you can get it scanned
    P.S. dont expect much power from a stock 1.8t, they only have 110kw. MK4 GTI is the slowest GTI VW has ever made
    1991 BMW 318is RED E30
    Aug 2006
    I had the same issue.. Was my coilpack..
    Oct 2010
    northern beaches nsw
    you sure it,s stock mate.Turbo seems to spool much quicker than usual stock mk4.Can,t usually here the spool either.Can I here a BOV maybe??
    MK4 GTI Revo Stage 1 / BFI Dogbone Mounts / 710N DV
    Jan 2011
    Gold Coast, QLD
    Since your running a pod, where is your ignition coil heatsink located now and is it getting enough air?
    http://www.vwwatercooled.org.au/foru...afe-45277.html
    Otherwise..
    Change spark plugs and clean the maf... they are cheap...
    If its sitll not fixed after all this.. replace the coil packs?
    anyone else got any ideas?
    Jul 2011
    Scan for faults!!!
    This should be the first thing to be done!!!!!
    might lead to issue???
    Jan 2009
    blankedy
    I agree with Bullsta, what diverter / BOV do you have? Sounds like its blocked off, which would be confusing the EC
    If its stock, could be bad. if its a BOV, get a diverter. If you don't know, do you know where to look?
    Coilpacks are a lot less likely that the Ignition amp on a MK4. The bolt down ones are pretty reliable IMO.
    Sparkplugs and MAF are worth looking at too.
    If you can't get it scanned, I'd do the plugs. Then try a MAF followed by an ignition amp.
    V A Garage
    Unit 3, 7 Olympic Cct, Southport QLD
    Adam - (07) 55 916 009
    www.vagarage.com.au
    Mar 2009
    Sydney boy
    My 4 motion had exact same problems replaced the MAF and all good now. I know its a different engine but its just an idea. Good luck
    Jul 2011
    hey all
    unfortunately after the good period im back to square one.
    VW Golf, Shaking, Lost of power - YouTube
    i havent given the MAF a good clean as of yet (with the MAF cleaners at supercheapauto, lol), but ive been told its probably a faulty coilpack ??
    if i drive with the studders, it sometimes have a intense burning smell.
    need advices please.
    the cars a 1.8t mk4.
    cheers
