Results 1 to 3 of 3
Thread: Rear Door Stuck on Mk4
    Dec 2009
    PERTH, WA
    I have a MKIV with the same issue, except it is the right rear door.
    PITA - It first started as an intermittent problem, but now is stuck in the locked position.
    I've read that faulty soldering on some of the wires in the actuator module can be a cause of this. Some lube would probably be good once I have my apart.
    What lube should one use for these things? Graphite? WD40 etc?
    I read info on how to remove the inside door cover here.
    http://www.agthompsonfamily.com/vw/WindowRegulator2.jpg from this thread http://forums.vwvortex.com/zerothread?id=1015107
    From this picture, could you loop some thin guage wire down the button slot and pull it up? I might give it a shot this evening.
    Zano - PERTH, WA
    MY09 Golf MKVI TDI 2.0, DSG, Sports Pack
    Dec 2009
    PERTH, WA
    Still struggling with this, but found this!... Will try shortly...
    http://forums.vwvortex.com/zerothread?id=4209343
    Zano - PERTH, WA
    Mar 2007
    sydney
    i have the exact same problem on my rear rhs door. got worse & worse. let us know how you go
    2004 GTI, GIAC, DOWNPIPE
    2007 R32 3DR MANUAL
    2010 NAVARA D40
    2016 Q7 4M 200kw
