Results 1 to 10 of 36
Thread: R32 Understeer
    May 2010
    Perth
    i found the understeer on the bora pretty bad, even with coilovers and a haldex controller, especially at the track.
    cant get away from a fwd biased drivetrain with heavy engine out front, and engineered to be very safe under all conditions
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
    Apr 2008
    Quote Originally Posted by Lonewolf1983 View Post
    Doesn't help that even the blue controller cuts power to the rear under brakes. Need the competition controller to remove that behaviour.
    All that said, the "lead-tipped arrow" nature of the beast doesn't help, as you've suggested - you can't overcome the rules of physics - if you move something heavy quickly in one direction, it'll keep trying to move in that direction despite your efforts to turn the wheels
    Nothing to see here...
    May 2010
    Perth
    Every car will understeer into corners if you are hard on the throttle, it all depends on what you are doing.
    As others have said,
    Sticky tyres
    Haldex
    Rear sway bar/ Upper bar
    will help
    Stiffer suspension and lsds make a big difference too.
    Cheers, Pedro.
    '76 Mk1 LS
    '04 Mk4 .:R32
    '09 Audi S5
