Results 1 to 10 of 13
Thread: New Beetle - adding cruise control
Threaded View
  1. #3
    Nov 2012
    Geelong, VIC
    Only for Petrol Engine Codes; APF, AQN, AQP, AUE, AVU, BDE, BEH, BFH, BML, and 1.9 TDi Diesel Engine, with Electronic Throttle Control (ETC)
    Other engines require extra wiring harness not covered here.
    Is your engine one of those listed? Also, have you tried to enable it in the ECU? I know it's not wired in but the ECU doesn't know that. It should confirm it as taken the coding change if it works.
    Thanks Gavin. Hadn't noticed that bit as I was mainly using the article as a RH drive Beetle photo reference. The instructions that came with the stalk/loom said it was for any MkIV with electronic throttle
    Haven't tried enabling it in the ECU yet. Was planning to get that done once it was all wired in as I don't have my own VCDS cable.
    Might be time to re-assemble everything as is and do a bit more research I think...
    Edit: I've got BFS engine code.
    Steve
