Hi All,
Just on the way to work my right indicators stopped working, if I hit the hazards or unlock / lock the car they all light up. It looks like the stalk is playing up, I figured out if you push it a little bit out and up the right indicator turns on.
Anyidea the cost to replace the stalk or if its fixable?
2014 MK7 R
2014 Audi SQ5
2022 Tiggy R
2022 Tiggy 162 Allspace
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff| Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
Cheers, tried that already.
The weird thing is, although the right indicator doesn't work if you turn the car off and leave the right indicator on the 'one side parking lights' feature works. From my understanding that uses the same switch just does a different function if the car is turned off.
2014 MK7 R
2014 Audi SQ5
2022 Tiggy R
