Results 1 to 2 of 2
Thread: Need ID on this item for re trim
    Mar 2015
    Ingleburn, NSW
    Hey guys,
    I'm currently in the process of buying all the items for a full re trim in black for my 03 MK4 Golf Gti , I have all the parts needed but I'm uncertain what this part is called
    Is this the Left/Right door sill trim? 403 Forbidden
    If so the above link is the correct item to buy correct?
    Attached Thumbnails Attached Thumbnails Need ID on this item for re trim-f5z3ej5fscewzmipki-large-jpg
    Jul 2007
    Brissy
    The white felt bit is part if the body seal.
    The felt is not a separate part, you have to buy the whole seal that runs around the door opening. About $125 from the dealer.
    The link shows a plastic part, which looks to be the section that runs along the door sill, and meets the lower section of the B pillar. it is also for the a 2 door model so will be longer than that of the 4 door. You would need to remove this section to take off the body seal.
    The easiest way to get the correct part is to remove it and look for the part number.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
