Page 64 of 96 FirstFirst ... 1454626364656674 ... LastLast
Results 631 to 640 of 956
Thread: My Mk4 buildup thread...
  1. #631
    Quote Originally Posted by Golf Dvr View Post
    Hi guys, I could be wrong, but if you go with a lightened flywheel than torque will decrease due to a lighter spinning mass and vice versa, a heavier flywheel will increase torque, so a single mass flywheel of similar weight to the dual mass would not decrease the torque. I only bring this up because one of the first recommended mods when increasing HP figures for the 1.8T is to replace the dual mass fly as they don't like to much HP. And then increase the clamp force of the clutch.
    If this info isn't correct, I would like to know as this would be one less thing on the mod list and could be oney spent else where.
    Cheers Troy.
    Hi Toy and welcome aboard.
    I have been running the dual mass since I got the car and mine has had the works done for a car still running the standard turbo and I have never had a problem with it.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
  2. #632
    Cheers Troy.
    The best reason for going to a single mass is the larger diameter plate you fit. The VR6 clutch is easy to get hold of too.
    The single mass does make the drivetrain shunt a bit, when going on and off the throttle.
    I would only go SM if you need the extra clamping force because you have got more than a stage 1 chip. ie You have fitted a bigger turbo. I think in a MK4 a std clutch would be ok with up to 230 crank HP. Unless you drive like a complete Muppet, it should last several years of driving easily.
  3. #633
    Hamilton NZ (Aussie Born)
    Cool
    Cheers for the info guys, i can now put this mod further down the list and move something else up to take it's place.
    2000 VW Golf GTI
  4. #634
    I would leave it until it starts to slip.
    Mine went while backing a trailer up a steepish driveway. I managed to run it around for a week or so but it wouldn't have lasted a lot longer.
    Certainly get the parts located, so you know the lead times you will need to apply. Golfloon has flywheels in std and lightened forms most of the time. A syd VR clutch will take 300hp if you are sensible.
  5. #635
    Nov 2006
    Cheers Troy.
    Less rotating weight = more torque. You can't create torque by adding extra weight to the driveline.
    All the dual mass/heavy flywheel does is make things smoother, engine changes less apparent. Ie - Light flywheel = Engine spins up faster + revs drop faster.
  6. #636
    Jun 2006
    Orange NSW
    Quote Originally Posted by SoVeReIgN View Post
    Correct. The rotating mass of the flywheel is just the same as the weight of the car. The engine has to drive it/make it move.
    "More torque" is not the right term. The flywheel (when rotating) has stored rotational energy, the heavier the flywheel, the more stored energy, which means that it takes more effort to slow the flywheel, hence the "appearance" of more torque.
  7. #637
    Sorry for the miss representation guys, the "appearance" of torque was what I was trying to get at, a motor produces "same" torque regardless of clutch flywheel setup, seat of the pants meter says there is more "torque" with a heavier flywheel.
    2000 VW Golf GTI
  8. #638
    Dec 2007
    Ermington, Sydney
    Haha you put that well, Dvr.
    Keep us posted Neil! I wanna see your crazy smurfy car go wossshkakakaka
  9. #639
    Well - the LM's are back on and I think they look better. I have brought the rears in 5mm and pushed the fronts out 5mm. It looks much more even now and I'm pretty happy with it.
    My new strut brace is in as well as my rear stress brace. I must say they look the dogs bolloks but I doubt I'll observe any realy bennefit for day to day driving. Track time they will be a great help but you can't do silly stuff like that on the streets.
    I'll get some photos when it's day light again.
    Oh yeah - I also got my BBS centre caps! They look much better with them on now. Big thanks once again to the boys from TCCA. The TST rear stress brace is a royal pain to fit and they did a tops job. thanks again guys!
  10. #640
    Dec 2007
    Brisbane, Southside...
    Quote Originally Posted by 99gti View Post
    What the emoticon above said
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
