Results 1 to 10 of 16
Thread: Mk4 gti head unit install, need help!
    Nov 2013
    So i'm looking at installing a sony head unit in my 1999 mk4 gti and was wondering if there is a wiring harness that will go straight from the eurovox one to a new sony head unit?
    if not was just after people's input as to what is the best way to go
    p.s. i have moderate wiring know how
    should be able to get one.
    I got some generic thing from super cheap for my GFs car.
    get sony to iso or something
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Sep 2012
    Wonga Park, VIC
    there was not one I could find 18 months back, I got myself a pioneer to iso, then had to do some swapping of pin locations
    Eg. the power and the ignition were in the wrong spot on the iso plug, so when you have everything connected, the h/u is always on..
    you just staying single din? if so it's pretty straight forward, otherwise you have to remove trim
    Untitled Document
    or
    shows you how to pull everything out, so you just find what you need to access behind the h/u
    VWVortex.com - My interior makeover (long... dialup beware!) - 2nd coming!!!
    Aug 2011
    melbourne
    buy clarion, not sony. Similar price for much better source unit.
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
    Nov 2012
    Melbourne, VIC
    Quote Originally Posted by leighaus View Post
    The truth
    Sep 2012
    Wonga Park, VIC
    6V RCA out yeahs?
    Nov 2013
    yes just single din, having trouble getting stock player out though -.- does that empty box above it just pull out?
    So iso plug is same shape as existing harness but just needs pins swapped around?
    Nov 2013
    Quote Originally Posted by Swainey32 View Post
    Untitled Document
    or
    Adelaide hills, SA
    You still will need to modify the wiring unless there is a patch lead.
    Sep 2012
    Wonga Park, VIC
    Quote Originally Posted by danegti View Post
    you need removal keys, if you have 2 holes each side of the unit
    Saab VW Mazda Audi Factory Radio Removal Tool Keys | eBay
    Otherwise just ebay search vw radio removal keys
    If you make an improvised version of the removal keys, the clips sometimes break, so only way to get it out is to really yank at it with the keys pushed all the way in.
    Yeah the iso is basically aftermarket radio plug translated to euro plug's.
    As previously said, just make sure you switch the power and the ground locations
