Results 1 to 10 of 13
Thread: mk4 golf license plate lights not working
    Dec 2013
    hey guys i had led number plate lights previously and i bought a interior kit and it came with license plate lights as well. the new ones were alot brighter so i put them in and when i arrived at my mates i saw that they stopped working. i tried putting the old leds back in but they dont work as well. anyone got anything on this?
    Feb 2014
    I tried to install LEDs in mine and when i put the second one in they both stopped working. I read on some other forum that one guys replaced his door harness and that fixed his number plate lights. I know my harness is worn cause the puddle light and the interior lights don't react when I open the drivers door. The door harness is a common issue for all mk4's.
    blew a fuse?
    iv run LED number plate lights for a good 5 years now no problem
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Dec 2013
    Quote Originally Posted by Juls View Post
    door harness? as in the rubber seal?
    Dec 2013
    blew a fuse?
    yea the old leds were working fine untill i put these in it could be a fuse ill have a look tomorrow cheers
    Feb 2014
    The harness runs through the rubber grommet tube bit that you see when you open the door up. The mk4's (golf/jetta etc.) came out with a harness shorter than required and as a result the wires go bad overtime. I don't see why the license plate lights would be connected to the door harness in any way. With any luck yours is just a fuse though
    actually if I recall correctly it makes a difference which way you put the LEDs in. flip them around (both new and old)
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Dec 2013
    ive flipped them both with the new and old ones im going to try the old globes today when i fit my roof racks but if that doesnt work ill have to go get some fuses
    Why not just check if the fuse is blown, takes 2 seconds
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Dec 2013
    what fuse am i checking? would you know?
