wanting to get them wired to come on together via the stock switch?
cant see why not. there is just a switch wirer coming from your after market ones that needs to be tied in somewhere...
Hey guys.
I did an impulse buy a couple days ago and ordered fog lights for the lower guard on my golf. I currently have the integrated Fogs in the headlight....Would i be able to get them rewired to the new fog lights that i have ordered?
Plus do you reckon it will look good? (H3 white light will be the bulb)
Yeah it will come to connect to the stock switch.
I was thinking about re-routing the wiring from the integrated fog light in the headlight to the new fog lights so it works the exact same.
here is a picture of it....(its upside down for some reason lol)
I have never seen a MK4 with these so i wanted them
should be no worries.
I had some in the lower grills, they started off as leds then i fitted some narva driving lights. But it was a tight fit so i lost the hieght adjustment on the driving lights. Will making fog drivin even better if you fit a yellow bulb.
Thanks for lettin me kno if they will work![]()
