Results 1 to 10 of 13
Thread: Leaky R32
    Feb 2008
    Auckland NZ
    my GTI golf use to do the same thing,
    Ended up under the Raintray cowling, on the drivers side is a single vent covering the ECU and all the Cars wiring. It had a slight leak, So when it filled up on the right side, it would then seep in slowly, then go under the carpet and fill up from the rear.
    Hope this helps.
    Audi S4 (2001) - Imola Yellow
    Secret Project
    Nov 2008
    Northern Sydney
    Pics as promised...
    The water is 'pooling' just above the oval shaped hole in this picture where you can see some dampness.
    The seals all look good here on the door...
    When the water pools it seems to go over near where the middle of the silver bar is
    2010 Skoda Octavia vRS Wagon
    Aug 2007
    I suggest use a second party. Hose the car down for a fair while and sit inside and watch for ingress.
    Jmac
    Alba European
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by Jmac View Post
    Jmac
    yes i agree with this method....strange problem thou
    Dec 2008
    I had a leak in the rear foot well on my passenger side in my r when there was heavy rain. Problem was the seal in the pollen filter housing. Such an annoying problem. All fixed now. There is a thread floating around somewhere on it. Good luck mate.
    Nov 2006
    Brisbane Qld
    Looks like its coming in thru the door itself somewhere to get water there....unless you have MAJOR flooding inside.
    If the regulators in the door have been replaced then the metal inner liner might not be sealed properly against the door skin now.
    I have heard water getting in thru the mirror mount too. Water can run in along the wires from the mirror motor into the area behind the door trim, so it would end up on the door jamb like that.
    Or it is the door seal itself as others have said.
    Check the drainage holes in the bottom of the driver's door. 90% sure that there'll be a blockage there.
    They look like this, on the bottom edge of the inside part of your door:
    Use some fuse wire or similar to push anything out. When they fill up, water will start to come out through other parts of your door.
    http://www.cardomain.com/id/sydvr6
    Subaru WRX Wagon 06 + Peugeot 306 GTi6
    Aug 2007
    Quote Originally Posted by graeme86 View Post
    Which leads me back to - Water test the thing. Sit inside and have a 2nd person hose it for a while till you see ingress
    Jmac
    Alba European
