Results 1 to 8 of 8
Thread: Installing new front rotars and pads - bora 4mo
    Mar 2006
    Bunbury, WA
    Hey guys did a quick search on the forum about installing new rotors and pads into a 2001 Bora 4motion, couldn't find anything.
    Gonna tackle installing them myself this weekend, is there anything I should watch out for?
    2013 Skoda Superb Elegance
    2001 Bora V6 4motion
    Apr 2008
    This shouldn't be a difficult job. I'd do a fluid replacement at the same time - make sure you bleed out all the old fluid!
    What rotors are you getting? DBA do a stock rotor replacement for ~$150, or ~$260 for a slotted 4000-series rotor to suit.
    Nothing to see here...
    Mar 2006
    Bunbury, WA
    Quote Originally Posted by Manaz View Post
    Thanks
    I got stock rotors from Golfwagen in Perth, don't really drive the car hard enough to put a case to gf to get slotted rotors
    Apr 2008
    That's fair enough - I don't think most people drive hard enough to need slotted rotors
    Oct 2006
    Put some anti seize paste on the hub making sure not to get it down the bolt holes. Makes removing rotors so much more easier the next time around
    Aug 2007
    Perth, Australia
    If you are gonna replace the braking fluid you'll need vagcom to get the air out of the abs pump. You'll need to bleed the master brake cylinder as well. Its a pain in the bum
    1991 BMW 318is RED E30
    Dec 2007
    Brisbane, Southside...
    I'm guessing the rotors are vented ones. Make sure you get them around the right way. They should be marked left and right if they're OEM rotors but yeah if you install them the wrong way around direct air flow correctly.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Jul 2007
    Brissy
    Lube the caliper guide pins
    Don't breathe in too much brake cleaner spray
