Petrols can take a bit of a drink and still live (diesels can't - a capfull of water into a diesel will bend all the rods).
First check the oil, see if its cloudy, if it is change it and the filter - that goes for gearbox etc as well.
Pull the plugs out, pull the piping off the intake/turbo/intercooler etc and make sure there is no water in there, the last thing to want to do is suck more in, and turn it over on the starter motor, if you see water spitting out the plug holes its had a drink, keep turning it over untill its not spitting anything out, put the plugs in and have a go starting it with the aircleaner out (that needs to go in the bin if it got wet).
If it doesn't start, but turns over happily its quite likely you've sucked water into the electronics and its just a matter of waiting for them to dry out, if its making noises, chances are you've bent a rod and its going to be expensive.
If it starts but doesn't sound right TURN IT OFF and take it to a mechanic, an engine with a slightly bent rod can run, but at the slightest rev can snap and punch a hole in the block (I've seen it happen with my own eyes).
If its had water over the level of the ECU chances are the insurance co will write it off regardless.
Thank your lucky stars its not a diesel, that WOULD be dead, this might be ok if you are lucky.
Its here!
A paper filter would probably be stuffed. If you have an after market cotton filter, POD etc, then you should clean it and if required re-oil too.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
The reason diesels are so much worse is they run much higher compression ratios - which just amplifies the issue that you simply can't compress a cylinder full of water.
Driving a car through water at headlight height, given the air intake position directly behind the headlights though, I'd guess it probably copped more than just a "bit of a drink". The R32 (owned by "r32 uberwagen") that recently died is proof that you can indeed kill a petrol engine this way.
Regarding the air filter - it's a $20 part, $40 if you try get it from a dealership. Given what's happened, why risk trying to reuse it?
If you're not sure, get the car towed to a mechanic and get it checked out.
Nothing to see here...
its not looking good... done most of this stuff but it just wont turn over battery is charged and its on jumper leads....![]()
2000 Golf GLE Auto - stock
Perth's slowest golf because im broke
just a question wat was going through your mind to even consider driving through flood waters?
