Results 1 to 8 of 8
Thread: 2.0 petrol bora exhaust emissions check light
    Aug 2011
    brisbane
    is this light supposed to come on whenever the car's ignition is switched on, it does go out after the car is started. just don't recall seeing it before. the car appears to run and smell quite rich at the moment, leaving soot on the driveway, and the fuel economy is crap, only getting around 400k's out of a tank
    [IMG][/IMG]
    Check engine light?
    Standard mk4 item :p
    Regarding the overfueling, go get it scanned.
    Prob a o2 sensor or maf died or something
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jul 2007
    Brissy
    Check engine light?
    Yep probably spot on.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Mar 2013
    Brisbane QLD
    should always come on with ignition and crank and then go straight out, if stays on then you have a issue...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Mar 2013
    Brisbane QLD
    these motors are common for O2 No1 sensor and airmass meter issues giving poor acceleration..poor fuel eco ..running rich.. more than likely get the engine check light coming on soon if thats the case... also breather hose on cam cover breaks off causing poor idle and emissions issues..VDUB...400KM to a tank is crazy!! glad i have my 1100km to a tank tdi! ... kidding apart you must have a issue to drop that bad on fuel...
    Aug 2011
    brisbane
    Quote Originally Posted by vdubmotorworx View Post
    pm sent
    Aug 2011
    brisbane
    thanks for the advice, will check a few things first before i call in the experts
    Mar 2013
    Brisbane QLD
    pm replied mate ...
