Results 1 to 10 of 20
Thread: engine stop while on idle. help please!!!!
    May 2009
    Canberra
    hi every one, i'm having issue with my car, for some reason i'm sitting on the traffic light and suddenly the engine stop, it happend twice today, before and after i replace the spark plug. no idea what is happening, dose any one have this problem or had this problem?
    2009 Tiguan TDI and 2007 Passat TDI
    Apr 2008
    Best bet would be to get it to someone who can run VAGCOM over it and see what error codes the computer's throwing...
    Nothing to see here...
    May 2009
    Canberra
    i think its the alternator
    Apr 2008
    Why do you think that? It's unlikely that the alternator will cause the engine to stall (though the cluster can throw up a "check alternator" or similar warning because the alternator also stops when the engine stops).
    May 2009
    Canberra
    good point manaz, now it's making me think again, back to squre 1, CRAP!!!
    Apr 2008
    Seriously, get it checked with VAGCOM. The error codes will likely tell you where the issue lies, removing a large amount of guesswork.
    Whereabouts are you located (if you fill in the location field in your profile, it helps people match you to services in your area for things like this)?
    May 2009
    Canberra
    i'm getting it service today, hopfully i'll find out today and fixt it.
    Apr 2008
    By a VW dealership, or someone who's a VW expert?
    Some "generic" workshops may not be equipped to scan the ECU and find the error codes.
    May 2009
    Canberra
    yes that is true, i'm getting it scan in 2 different places and see if i get the same outcome.
    btw profile location updated.
    Nov 2008
    Sydney, Macquarie Park
    it might not be a fault. does it show "service now" on the trip computer? i remember when my did the engine would automatically shut down at idle (some crappy safety feature). i simply reset the service interval and it was fixxed.
    '01 VW Bora V6 4motion - gone
    17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
