Results 1 to 9 of 9
Thread: door switch is being a pain in the a**
    Aug 2007
    doncaster, vic
    my drivers door sometimes doesn't trigger the door switch when i open it.
    which means the int lights dont turn on and that noise u hear when u open drivers door doesnt happen also.
    its that bad?
    is it an easy fix...
    my old 2.0L did it too!!
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
    Aug 2007
    doncaster, vic
    no 1 knows what im on about? hehe
    Have you had a look at the actuator for the switch? Does it all look to be intact?
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    May 2007
    Moonee Ponds
    The doorlocks in the mkIV cars are electromagnetic.
    Sounds like your module has some problems. To fix this, it involves stripping the door, removing the door module and investigating the switches/solder on the module. There is a guide to do this on the vortex forums.
    Good luck, I had mine fixed underwarranty. I have a spare module from mine but I still have to fix it !
    To get a second hand one installed about 300 to 400 $.
    While you are there do the window regulator
    Ciao.
    Aug 2007
    doncaster, vic
    oh lovely.
    does anyone know what that noise is when you open your door?
    May 2007
    Moonee Ponds
    I think it is the fuel pump being prepped. BTW what wheels do you have ?
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by NGOLF.U View Post
    oh lovely.
    Flux Capacitor warming up!
    Aug 2007
    doncaster, vic
    so is this a problem if the door doesnt activate the flux cap before i drive
    May 2007
    Moonee Ponds
    not sure. My guess is by turning the key in the ignition, it preps everything anyway.
