Same problem here. The plastic bits that hold the metal pins break off
No solution that I know of.
Hi all,
I took the trims off around the radio/climate control the other day and I appear to have broken the mounting points for the vertical pieces. Ive had to blu-tac them on for the moment. Just wanted to know if anyone else has had this problem and if so is there any way to fix it without replacing the cage?
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
iv broken the clamps too.
think it requires gluing or fixing the trim as you have done, or a whole new surround
Happened on mine two, Just glue them in.
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff| Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
I found this
Volkswagen Jetta IV VR6 24v > Interior > Trim > ES#311608 Radio Trim Cage - Black - 1J1858069M2AQ
but the trims are only in black which i dont want. im hoping for brushed alloy but i dont want to pay 1500 for the set from ecs.
Yeah thanks for the tip, i was just using that as an example of the part.
Do you guys know of any Aus based ECS type sites?
UK Sites are the best bet
Here is heaps of info and some part numbers
Replacing radio cage parts - uk-mkivs
Looks to be the G revision for RHD removable sides 1j285069G
MK4 GTI - Sold
eBay Australia: Buy new & used fashion, electronics & home d ich bin hungary, that's all the German i know.
Thanks mate. I think im gonna go with the door handles in just beige
