Results 1 to 10 of 18
Thread: Changed my coilpack and found rust??!!??
    Jun 2008
    Cronulla, NSW
    Went to change a dead coilpack tonight that i found via the "Loon Illimination" method, and found the damn thing to be rusted like its been on the poopdeck of the Titanic.
    I feared that maybe I've lost a head gasket, or worse, but then good ol' Father-in-Law comes out and reckons it absolutely fine and that water would get in no worries but the unit is sealed and would stay carry a charge.
    I don't really want to pull the others as I haven't the right tool (am only using a pair of pliers), but need my ride for tomorrow and need to get her fueled up so was just looking for the collective opinion if she is fine?
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Sep 2010
    Melbourne, Victoria
    Doesn't exactly seem like rust; looks more like oil leaking from your rocker cover gasket onto and around the coilpack boot. Maybe abit of moisture in there as well. It's not your head gasket.
    Jun 2008
    Cronulla, NSW
    when i pulled it out (quickly i might add) i got a few drops of water on the top of the engine (intake runner?) and the coilpack just smelled like it was rusty. I can't imagine the rocker cover gasket, but would imagine if oil can seap out then maybe water can get in?
    Either way, feel this is fine to drive with? or is it symptomatic of something that warrants attention?
    Jun 2008
    Cronulla, NSW
    Well, nothing has gone pop, fizzle or bang in the engine bay. yet
    Driven probably 100kms so far today with varying rev ranges and everything is sweet.
    May 2009
    North Brisvages
    Mate if you haven't had it from new Or have had it detailed and they power washed your engine bay wouldnt put it past that as an explanation.
    Sep 2009
    Yeh dont worry about it, one of mine is like that. I figure its just from washing the bay.
    What do you mean by the right tool to remove them? I've always just pulled them out by hand?
    Jun 2008
    Cronulla, NSW
    .... and then i found sludge. wtf?
    Check the pic below. Basically the plugs were pulled in that order, so the driver side plug is #1 and so on. I kept one or two of the coilpacks as they looked relatively good (No real indicator i know) but the other plugs and coilpacks looked feral. Is this normal?
    Car does run nicely now though
    Jun 2008
    Cronulla, NSW
    hahaha, check plugs 4 and 6!! thats not normal.
    Sep 2009
    Certainly right that plugs 4 and 6 look pretty shabby! The only one that worries me out of all of them is 6 because the rust clearly has penetrated past the seal and rusted down the threads! This just likely means that that plug wasn't fastened properly but its not a good thing as you would likely have been blowing compression (and thus fuel and air mixture) past that one thus not only dropping power but also altering the fuel mixture in that cylinder.
    Oh well i'm sure all should be well! Makes me wonder what mine look like... although that said, i accidentally spilt a heap (read filled the spark plug holes) of oil down 5 and 6 when i had the coil packs out the other day so i dare say they wont rust! Hard as i could try there's still oil traces down there... oops!
    Anyway back to yours, might feel a bit better now that all is fresh!
    Jun 2008
    Cronulla, NSW
    My torque wrench is 1/2inch and the plug socket was 5/8inch, so I didn't torque the plugs down.
    Can they be over tightened?
