Results 1 to 7 of 7
Thread: Can the rear be aligned ?
    Jul 2007
    Brissy
    Can a rear wheel alignment be done on the Golf ?
    I just got my car back from the tyre shop and the invoice says 'REAR IS NOT ADJUSTABLE', so they charged only for a front alignment.
    The rear tyres are wearing on the inside and I want this fixed !
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Aug 2006
    Melbourne VIC
    The rear end is a fixed beam. The location cannot be moved to my knowledge. Thats my people get camber/castor correction kits.
    Jun 2008
    Cronulla, NSW
    the rears on the 4Mo have a bit of play in them, but most opt for camber shims or the adjustable rear control arms.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Aug 2007
    Perth, Australia
    i had my rears alighned to try to get rid of the undrsteer, but not much tho
    1991 BMW 318is RED E30
    Jul 2007
    Brissy
    This is for my GTI. It has a fixed beam. So the Bora 4mo and R32 will be totally different.
    MK4 GTI - Sold
    Apr 2008
    Quote Originally Posted by balkanac View Post
    Changing the rear alignment doesn't change the laws of physics.
    A 3.2L cast iron block engine ahead of front axle with a largely FWD drivetrain driven too fast into a corner for available mechanical grip to hold it = understeer. End of story.
    Your BMW will understeer like a pig too if you go into a corner too hot and off the power. You only get power-on adjustability in corners in your BMW because your rear wheels are driven rather than the fronts.
    Nothing to see here...
    Aug 2007
    Perth, Australia
    Quote Originally Posted by Manaz View Post
    After i had the rears adjusted, took it on a short track and half of the unersteer was gone. I was on the same track a month before that and the understeer was crazy! Alignment was done by Wheels World in perth, they look after porches, ferraris and those kinda cars, they know what they are doing
