Results 1 to 10 of 15
Thread: Bypassed N75
    Sep 2008
    Launceston
    Bypassed N75
    I've only just noticed that my N75 valve has been bypassed by the previous owner at some stage. Has anyone here done this on there car?
    There are few guys on vortex doing this to fix boost surging.
    Aug 2007
    And put what in place???? N75 is the boost controller valve and has a duty cycle controlled by the ecu and wouldnt mess with it unless you are using an alternative controller adjusted correctly, unless you want a ticking bomb in the engine bay.
    Jmac
    Alba European
    Nov 2008
    Canberra
    Quote Originally Posted by ntails View Post
    Do you perhaps mean the N249 valve which controls the wastegate, and can be bypassed to help control surging? I can't see how the car would run for long with the N75 completely out of the loop.
    Sometimes replacing the N75 with the N75J version also softens the surge a bit - I've done this on a Polo.
    Dec 2007
    Girraween
    Quote Originally Posted by Catfish View Post
    The N249 controls DV , the N75 controls wastegate
    Nov 2008
    Canberra
    You're right - my mistake.
    Sep 2008
    Launceston
    The N75 is still plugged in, just the hose is looped back on itself. There is a MBC in its place, which i am assuming was put in when the car was chipped, once again by the previous owner.
    Max boost is ~12psi.
    So with the MBC it is ok to have the N75 bypassed?
    Oct 2006
    if the car was 12psi it was definitely not chipped.
    it was put in place to try do the dodge and get more boost, its not good for the car and no increase will come out of it imo.. go j or h valve and get a chip and you will get the performance change what you'd be wanting..
    Sep 2008
    Launceston
    Is there anyway to confirm if the car has been chipped or not?
    Oct 2006
    How well the car goes, boost gauge on it to check what your getting prob the easiest
    you can tell a stock gti vs a chipped gti .. stock gti = hyundai getz lol
    Apr 2008
    Quote Originally Posted by fuzion View Post
    I watched the Top Gear Episode recently where they race a stock Mk4 GTI against a diesel Skoda Octavia and another car (a frenchie IIRC) - and the GTI comes stone, motherless last.
    They then drive the Mk5 GTI and it's all smiles, sunshine and rainbows again.
    Nothing to see here...
