Results 1 to 4 of 4
Thread: Buying an ODB Reader?
    Sep 2009
    Woodville North, SA
    Hello all, I am pretty new to this stuff. Anyone have any thoughts on a good ODB reader for my Golf 2001 1.6? Having some intermittent starting issues and suspect some sensors. I have been on ebay an there are a pethora available. Any advantages in using a laptop vs a stand alone unit?
    Regards,
    Jan 2011
    Gold Coast, QLD
    Hey,
    The easiest way is to approach your friendly local VW mechanic and they will most likely scan codes for free.
    Last edited by JustCruisn; 27-07-2012 at 02:12 PM. Reason: Removal of illegal references
    Nov 2006
    Largs Bay, S.A.
    I have a standalone unit which is good for scanning/resetting codes, but that's about it. I'd go a laptop if you want to do anything more than that.
    Edit: Actually just noticed you're local - if you want to scan your car let me know.
    Jul 2009
    Geelong, Victoria
    depends what you need/want to do.
    An obd reader will scan codes, clear most faults and perhaps some very minor other things, depending on the type.
    If you spend around $300 and buy a proper vagcom cable (dont mess with the cheapies), then you can use that and a laptop to do most of the coding you will ever need.
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
