MOTOR-TECHNIC
Part No. Description Retail
AUD
NEW OETTINGER CARBON LINE incl GST
OE 340 010 00 CARBON-ALU STRUT BAR - for 1.8 Turbo engine $599.00
OE 722 051 00 CARBON "ENGINE COVER" - for 1.8 Turbo engine $650.00
OE 722 055 00 CARBON „AIR INTAKE SET“ - for 1.8 Turbo engine $699.00
OE 722 056 00 CARBON „AIR INTAKE SET“ - for 2.0l engine $699.00
OE 722 059 00 CARBON „AIR INTAKE SET“ - for 1.9 TDI engine $699.00
OE 108 401 00 INTAKE PIPE- 1.8 T, AUM, approx. 4-5 kW (5-7 hp) extra $499.00
OE 108 388 01 INTAKE PIPE- 1.8 T, AGU/ARZ, approx. 4-5 kW (5-7 hp) extra $499.00
BODY STYLING
OE 804 226 00 FRONT GRILLE $450.00
OE 804 227 00 FRONT SPOILER- replaces standard lower spoiler lip $795.00
OE 804 228 00 FRONT SKIRT Large lower fiberglass bar - attaches to original $1,050.00
OE 804 219 00 SIDE SKIRTS- set $895.00
OE 804 229 00 REAR SKIRT- replaces standard lower rear skirt, Saloon/Sedan only $795.00
OE 804 251 00 REAR SKIRT- replaces standard lower rear skirt, Variant/Wagon/Estate only $795.00
OE 804 238 00 ROOF SPOILER- Saloon/Sedan only $595.00
OE 804 230 00 BOOT/DECK LID SPOILER- with brake light, Saloon/Sedan only $950.00
OE 804 231 00 BOOT/DECK LID SPOILER- without brake light, Saloon/Sedan only $850.00
OE 804 232 00L SPORTS MIRRORS- left and right (set), LHD only. $995.00
OE 804 232 00R SPORTS MIRRORS- left and right (set), RHD only. $995.00
STAINLESS STEEL EXHAUST SYSTEM
OE 111 204 00 SPORTS REAR SILENCER- for all front wheel drive $1,495.00
OE 111 188 00 ADAPTER FOR REAR SILENCER - please use for 1,4 l + 1,6 l + 1,9 l SDI engines $69.00
1J0 253 144 BRACKET FOR REAR SILENCER - please use for 1,4 l + 1,6 l + 1,9 l SDI engines $39.00
OE 111 199 00 DOWN PIPE - for 1.8 T $995.00
BRAKES
OE 350 015 00 UPRATED FRONT BRAKE KIT- 320 mm front discs with 4 pot calipers $5,495.00
Caliper in black, red or yellow. Min. wheel dia. = 17"
CHASSIS
Saloon/Sedan, Front wheel drive
OE 410 062 00 SPORTS SPRINGS- 4 springs - 1,4 l + 1,6 l $595.00
OE 410 063 00 SPORTS SPRINGS- 4 springs - 1,8 l (not GTI) + 2,0 l + $595.00
all TDI up to 81kW with Manual/Stick shift
OE 410 064 00 SPORTS SPRINGS- 4 springs - GTI + V5 + TDI 85 kW + $595.00
all TDI Automatic up to 81kW
OE 410 077 00 SUSPENSION KIT- 4 springs/shock absorbers - 1,4 l + 1,6 l $2,195.00
OE 410 078 00 SUSPENSION KIT- 4 springs/shock absorbers - 1,8 l (not GTI) + 2,0 l + $2,195.00
OE 410 079 00 SUSPENSION KIT- 4 springs/shock absorbers - GTI + V5 + TDI 85 kW + $2,195.00
Variant/Wagon/Estate, Front wheel drive
OE 410 082 00 SPORTS SPRINGS- 4 springs - 1,4 l + 1,6 l $595.00
OE 410 083 00 SPORTS SPRINGS- 4 springs - 1,8 l (not GTI) + 2,0 l + $595.00
OE 410 084 00 SPORTS SPRINGS- 4 springs - GTI + V5 + TDI 85 kW + $595.00
OE 410 085 00 SUSPENSION KIT- 4 springs/shock absorbers - 1,4 l + 1,6 l $2,195.00
OE 410 086 00 SUSPENSION KIT- 4 springs/shock absorbers - 1,8 l (not GTI) + 2,0 l + $2,195.00
OE 410 087 00 SUSPENSION KIT- 4 springs/shock absorbers - GTI + V5 + TDI 85 kW + $2,195.00
FRONT WHEEL DRIVE, all version
OE 410 132 00 ADJUSTABLE SUSPENSION KIT- in stainless steel, without hardness adjustment $2,995.00
Front- height adjustable, max 65 mm lower
Rear- height adjustable, max 65 mm lower
OE 410 131 00 STABILISATOR-SET-consisting of stabilisator and 2 x self-aligning bearings, $595.00
please use for lowering with OE 410 132 00 of over 40 mm (Sway Bar Front
4Motion, all version
OE 410 130 00 ADJUSTABLE SUSPENSION KIT- in stainless steel, without hardness adjustment $3,295.00
Rear- height adjustable, max 50 mm lower
OETTINGER ALLOY RIMS
OETTINGER 18-inch, Type RE, 1-piece rims
OE 361 146 00 TYPE RE "silver" - 8.5 x 18, 35 mm offset, PCD 5 x 100 $825.00
OE 361 152 00 TYPE RE "charcol-silver" - 8.5 x 18, 35 mm offset, PCD 5 x 100 $825.00
OETTINGER 19-inch, Type RE, 1-piece rims
OE 361 149 00 TYPE RE "silver" - 8.5 x 19, 35 mm offset, PCD 5 x 100 $945.00
OE 361 155 00 TYPE RE "charcol-silver" - 8.5 x 19, 35 mm offset, PCD 5 x 100 $945.00
OE 361 138 00 TRACK SPACERS- 2 discs 5 mm each, set for one axle - for Oettinger type RE wheels only $365.00
OE 361 135 00 TRACK SPACERS- 2 discs 8 mm each, set for one axle - for Oettinger type RE wheels only $365.00
OE 361 117 16 TRACK SPACERS- 2 discs15 mm each, set for rear axle - for standard Audi wheels only $365.00
OE 361 132 00 SECURITY WHEEL BOLTS- for Oettinger type RE wheels only $179.00
OE 361 133 00 SECURITY WHEEL BOLTS- for fitting with spacers OE 361 135 00 or OE 361 138 00 $179.00
INTERIOR
OE 551 007 00 FLOOR MATS- set of 4 in black, charcol, blue or red, LHD / RHD $395.00
Please give model year when ordering
OE 722 037 00 ALUMINIUM GEAR KNOB- from 1,8 l on with Manual/Stick shift $295.00
OE 722 049 00 ALUMINIUM PEDAL SET- set of 3, for manual transmission only- for RHD only $395.00
OE 722 051 00 ALUMINIUM PEDAL SET- set of 2, for automatic transmission only- for RHD only $395.00
OE 722 045 00 ALUMINIUM FOOT REST- for RHD only $325.00
OE 804 236 00 DOOR SILL- set of 4 in aluminium look $299.00
OE 804 236 01 DOOR SILL- stainless steel, set of 4, for 4-door $299.00
I know for a fact there is more bits to this as iv seen a oettinger 4mo exhaust and lower grilles with my own eyes
