Also LED's won't heat up anywhere near as much as bulbs and will last much longer, plus they won't damage your electrical equipment through overheating.
My mk3 began smoking behind the position bulb of the headlight, I had to replace the wiring and socket. This overheating problem was the alleviated with using LED's.
They're fantastic! I recommend you use them. So long as they are white and not coloured to avoid being defective.
