Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Bora 4motion binding up when turning hard lock to left?
    Jun 2009
    Quote Originally Posted by analbora View Post
    It is like all four wheels are fighting each other when turning, almost like having air locked diffs on a four wheel drive, also will i have to take it to a VW Dealer and get raiped in the ass and pay a fortune or could i take it to a good mechanic if so any suggestions for S.E suburbs in Melb
    Jake
    if its resistance and fouling at all four wheels then sounds like diff.
    any good mechanic can work on these cars. they might not specialise in them, but it will get done
    my car's last owner had work done at volkspower
    Oakleigh VIC
    If it turns out to be the haldex controller you might consider an upgraded unit. In which case Volkspower as an APR (and therefore Haldex) dealer would probably be a good choice of mechanic
    http://www.goapr.com.au/products/haldex.html
    Might help you feel bit better than paying a similar amount for stock one from VW.
    I had a bit of a quick google about the place and came up with this little gem of information that you might like to try.
    For people with this symptom, try pulling up the handbrake just one notch, so the light comes on the dash to show its on, then try the manoevere. If it cures it, then it is the haldex controller only, one notch up disconnects the haldex. If it does not cure it, it is a mechanical issue with the haldex diff.
    As a check if haldex is working, s quick start with one notch on the Hbrake should set the front's alight, whereas without it should grip and go..
    Handy to remeber if you think you have haldex issues.
    It's off an Audi forum so I don't know how applicable it is. LINK
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Jun 2009
    i would definitely give that test a go.
    Apr 2008
    Avoid the dealer and go to VolksPower in Burwood.
    2000 Mk IV GTI
