Will be a wet clutch DSG.
Engine oil and filter every 15K/12mths
Air filter every 45K/3yrs
Fuel Filter and DSG service every 60K/4yrs
Brake fluid and cabin filter every 2yrs
Haldex oil (if 4Motion) every 3yrs
Hi there, I can’t find anywhere online the required items that need servicing, like dsg oil, brake fluid etc. Can anyone help me with a link?
Also ive read there’s dry and wet clutch dsg out there, what is mine or how do I find out? Thanks!
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Cheers, but is there an actual spreadsheet or something with everything like belts and other fluids?
is the dsg oil different to the gear oil or are they the same?
Only DSG oil in the DSG trans.
Manual gearbox, bevel box and rear diff (if fitted) is 75W-90 full synth. No set service interval for those.
One thing I forgot was timing belt is due every 105K/7yrs. Recommend doing the V belt and water pump at the same time.
'01 Beetle 2.0
I've been going off this
Sent from my SM-G950F using Tapatalk
I think that's a bit out dated.
The toothed belt on a 2.0 TDI is about 210k to 240k by memory.
Most of the filter stuff would be close though.
2018 Crafter Runner
2012 T5.1 6sp manual.
2024 Crafter Auto
No, the timing belt is still 105K/7yrs.
'01 Beetle 2.0
Post 2010......
YouTube
2018 Crafter Runner
2024 Crafter Auto
Not for the Australian market.
At 210K, you would be close to putting your third water pump in it by then anyway.
'01 Beetle 2.0
Pulled out the water pump on my second belt change (395k......I think) and it looked as good as the new one!
2018 Crafter Runner
2024 Crafter Auto
