Results 1 to 9 of 9
Thread: Running lights replacement
    May 2012
    EdenHillsSA
    I'm getting sick of replacing the filament style 21 watt run light globes which burn out with monotonous regularity.
    Do LED replacements exist, and are they likely to cause any hiccups with the "fault detect" system in the circuitry?
    Anybody out there who has actually done this replacement?
    Regards,
    Geoff.
    2011 T5 132kw 7spdDSG 4motion, '89 Citroen 2CV, 2006 Subaru Forester SG 5spd
    IN2VWS Guest
    I was thinking exactly the same thing a few days ago.
    Might get some and just try them.......Haven't got anything to lose really.
    Jun 2012
    Moorabbin, Victoria
    I replaced one of my daytime drive lights with and LED. No dramas, both LED & incandescent work fine.
    May 2012
    EdenHillsSA
    Quote Originally Posted by Zaskar View Post
    Thanks Zaskar ... any specs to look for, like lumens output/current draw?
    Or for that matter, any particular brand - and where from, somewhere like Jaycar maybe?
    Jan 2009
    The ECE specification for a category P21W filament lamp has a reference luminous flux of 460 lm at 13.5 V with a tolerance of +/- 15%.
    You may want to consider using Osram's Ultra Life range or Philips' LongLife EcoVision range of bulbs, which claim longer a lifespan. A pair of Osram Ultra Life P21W bulbs can be bought for about AUD 9.00 on eBay.
    It has also been suggested that removing and refitting the bulb may cause it to start working again, indicating a possible fault with the headlamp unit, so check the filament carefully before discarding the bulb.
    Jun 2012
    Moorabbin, Victoria
    I picked up mine tom Jaycar- they cost about $30 each. I only got one, but the sales guy was very confident with them.
    May 2012
    EdenHillsSA
    Thanks guys ... BTW, I figure that if the bulb has turned black it's a no brainer that it's beyond recall.
    Jun 2012
    Moorabbin, Victoria
    You could mulit-meter it to be completely sure, but as in the rule for steak - brown is cooked, black is fooked!
    IN2VWS Guest
    Bought 2 from Jaycar this morning. $19.95 each. No errors thrown up on the dash.
    Running lights replacement-586e7895-761e-4ff9-91de-4fc7a2214182_zpsmkl0xamh-jpg
    Running lights replacement-9bf93817-4eb4-40c1-8173-d9c495e556da_zpsoerr6uzd-jpg
