Not sure if they are the same as the van but I have done our two T5 vans with new coilovers and removing the old ones was a breeze . Jack up vehicle remove shock then use a second jack to lower the rear control arm it will swing down far enough to get the spring out with no compressors at all . In fact once the control arm is down it will nearly fall out on it's own .
- You may not post replies
- You may not edit your posts
Forum Rules
