Good to hear you don't have any major mechanical issues
Next step is to go back to basics and check to see if you have healthy spark at the coil
If not check that you have power and good grounds at both your coil and distributor
Then get a hold of a led test light and test at the coil to see if the ecu is switching the coil on and off
IMO you need to establish this before looking elsewhere
- You may not post replies
- You may not edit your posts
Forum Rules
