Results 1 to 10 of 12
Thread: Hiccup when accerating
    Jan 2007
    Have a 2005 128Kw 4Motion Multivan. Only done 77000 Km. Have noticed over the last six months that when accelerating in 4th (and possibly other gears as well) there is a slight hiccup in acceleration around 1700 Rpm. Could this be a turbo issue? Can you get the turbo serviced if needed?
    Golf V TDI 2005 - SOLD
    Volvo C30 D5 - I've got a hat as well!
    Multivan Highline T5 TDI 4Motion 2005
    Hond Civic VTI 2001
    Herro, you would think when accerating it would do it across the board really if it was the turbo not just in one gear?
    Jul 2005
    Newcastle, NSW
    It is probably time to have a good look at the EGR, how maybe time to clean the intercooler as well. I would suggest that it is more likely something is gummed up.
    Jan 2007
    Looks like a call to Transporter is in order ...Thanks, Mikinoz
    Hond Civic VTI 2001
    Jul 2005
    Newcastle, NSW
    My advice would be to consider an EGR delete and a Provent oil separator at the same time as you get everything cleaned as some long term preventative maintenance.
    sydney nsw
    could this "hiccup" be also described as a "shudder"? and is it ONLY at the 1700rpm? if so its unusual to have this problem at 77k. it usually doesnt hit people until 150-200k.get it plugged in to computer (while driving, not stationary).
    cleaning egr is always a good thing too. give it a flogging up a hill to potentially clear sticky vanes. and see if limp mode hits.
    Feb 2009
    Lake Cathie, NSW, 2445
    Had similar problem with mine. Turned out that air cleaner had not clipped under lugs on LH side of air cleaner box allowing minor dust entry. Cleaned the sensor (maf ?) outboard of the air cleaner on the inlet tube RH end of air cleaner box) Been good for 80000 km and no oil usage so consider myself very lucky
    Mt Cotton
    I wonder is your Hiccup at the exact time a gear change happens as we occasinaly get what could be interpreted as a hiccup when our T5 changes from 4th to 5th and then down change from 5th to 4th in our case we are certain its a tranny fault as it happens some days frequently then other days not at all. Howard
    Jan 2007
    Hiccup is just a momentary loss of power where acceleration drops, and only happens when in gear and not changing gears. We do tend to drive fairly conservatively, but did do a run over to the York Peninsula recently - but still not caning the engine. So I'll try for a long run soon as I'm up to a bit of a trip.
    Sounds like EGR from most of replies, so I'll have a talk to local friendly mechanic. (Miro - you here?)
    Rod
    Hond Civic VTI 2001
    May 2010
    Kilmore, Vic
    Quote Originally Posted by shogun2 View Post
    Rod, it's a diesel, give it some stick
    I also poke around relatively easily, so about once a week will pick a hill and go through a couple of gears up to 4000 rpm
    Even 3000 rpm is good, if you get there very quickly
    M
