Results 1 to 9 of 9
Thread: Day Light Running lights
    Mt Cotton
    Not for me but trying to help a friend , his T5.1 2012 has DLRs installed and wired but they don't work . Anyone have some ideas where there maybe a relay as I have tried all the fuses even ran my launch diagnostics but could not find any way of activating them , it did show the left and right one but when I try and activate them I get no response .
    Nov 2007
    by DRL installed and wired you mean what exactly?
    DRL on the T5.1 is incorporated in the headlight as standard, and should not be installed separately.
    Mt Cotton
    My mistake they have been there since new but not sure when they stopped working .
    Aug 2016
    NSW
    The bulbs on mine used to blow all the time on mine until I got some cheap LEDs ex China.
    As soon as one would blow, the other would follow not long after.
    2018 Crafter Runner
    2012 T5.1 6sp manual.
    2024 Crafter Auto
    Mt Cotton
    Quote Originally Posted by LogicprObe View Post
    The originals weren't blown just did not work . I see two sets of fuses so need to dig a bit deeper , I suppose I could bypass the vans system and use a relay to power them up and use 12v signal from the fuse box when ignition is on .
    May 2017
    Southern Highlands
    Are you 100% certain that the globes are OK? Have you pulled them out and checked them on a battery? The originals have a lifespan of 15 minutes.
    Nov 2007
    Can you post up a photo of the entire headlight? Is the single bulb (H4) or dual bulb version (H7 + H15)?
    Also, has it worked before? Or did he buy the car with it not working? Some people do turn DRL off with VCDS coding, could that have been done previously?
    In my Amarok (similar design) the H15 bulb (could be the H7 need to check) doubles as the DRL .... so as per syncro's question do all the bulbs work (low beam and high beam)?
    Mt Cotton
    Quote Originally Posted by syncro View Post
    Brand new led bulbs now fitted and the old ones were tested working out of the van .
    Aug 2016
    NSW
    Mine is the same van............although the basic model.
    Even with VCDS you don't get any info beyond not working.
    Although, I think you can code them on and off.
    I haven't looked at this problem for at least 5 years so I can't remember.
    I'm sure I saw the coding on the Rosstech forums back then when I was constantly replacing bulbs.
    edit - I've used Crafters for over 6 years so it's longer than that!
    (I still have the T5.1 though)
    2018 Crafter Runner
    2024 Crafter Auto
