Just as I thought, took the cluster apart and not a phillips head screw in sight, in fact no screws in sight!
Unfortunately, I am no electrician, but this is what I have done so far..
Swapped cluster - as above
Swapped sender unit (from drive shaft just under exhaust)
tested current at sender - plenty
twiddled cog in sender unit manually to make speedo jump - nothing
checked all associated wiring as much as possible
checked/cleaned up all the earths I could find
My next step would be to take it to a professional but I prefer to fix stuff myself, you learn more that way. Any suggestions greatly appreciated.
