Just bought this van. Checking model as buying oils etc as no service history for last 100K klms and has 300K on it. It's a T5 4Motion, built 04/04, complianced 02/06? Any help would be much appreciated.
diesel i presume? Info people!!
FAQ. Might not be current
T5 FAQ and How to THREAD (up to August 2009).
Your engine code should be in the front of your manual (AXE/BPC/etc)
Pump Deuse (PD) engines need 506.01 oil. It's hard to find.
here's some info, few years old though...
506.01 T5 Owner - where to purchase 506.01 spec oil??????
I'm using a Penrite 507.00 for my 04 AXE engine (don't tell Transporter)
They run narrow cam lobes, which results in high cam pressures. Can get cam probs with high mile vehicles, pulsing in intake at idle
https://www.youtube.com/watch?v=ocEkwMX0PBI
If its an auto(tiptronic), i strongly recommend getting rid of the standard coolant/oil cooler. The coldest your gearbox oil can ever be is the coolant temp, which is normally 90C.
This tends to cook seals and o-rings in the gearbox, leading to probs.
My auto was fully rebuilt around 180K and lotsa $$$$
Get yourself an air/oil cooler, gearbox should run a lot cooler. About $500ish
Steve
04 T5
