Results 1 to 10 of 13
Thread: Urgent help needed!
    May 2010
    Perth
    Urgent help needed!
    Today running errands in the beater parked at a set of lights the engine starts loosing its idle, drops to approx 200 rpm then dies completely. I started it back up and runs fine for a second then dies again... the damn engine revs and runs perfectly only it cant hold an idle. Spent about an hour this afternoon trying to find any vacuum leaks that might be occurring but came up with nothing...
    if you sit there with a bit of throttle on its be fine, but i really want to fix this before german car day on sunday.
    Any ideas?
    Thanks in advance!!
    Aug 2009
    I'll take a few stabs in the dark.
    1. Fuel pump relay
    2. Vacuum leak you might've missed haha
    3. Fuel pump itself
    4. Actual mechanical gremlins, literally.
    Feb 2007
    What motor and injection or carby?
    MK1 GLS 3door
    A4 B7 2.0T
    Perth. WA
    Idle shut of valve or power to this device. mine does the same thing ( red beater )
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Feb 2006
    Perth Western Australia
    if it is carby then could be the idle jet is blocked!
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
    Sep 2009
    Chillaxing in Tas
    i have same problem!!
    will hold idle nicely 30% of time, most of time i have to heel toe into intersection and hold throttle.
    Ive check all vacuum lines, ive cleaned out all the jets, resealed the carby base ect... all thats left to do is inlet gasket.
    My timing is set to about 6-8 degrees and the mixture seems nice, plugs nice brown colour on idle so its not lean :S
    <space for rent>
    May 2010
    Perth
    So I've tinkered with the idle screws and mixture screws, I had it idling fine again, drove about 1km and the problem started again... Grant can you explain how I can figure out if I've got the same problem as you? I'm coming tomorrow regarless but I'd love you have this sorted, will try cleaning the carb up tonight.
    Have your checked the rubber gasket between the manifold and Carby?
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
    Perth. WA
    Stick a multimeter or test light on the wire that goes to the idle cut of solenoid, round thing with terminal on the LHS of the carb near the throttle butterfly, ( lhs from the driving position !!) should have power when the car is running, none when the car is turned of ( valve closes to prevent dieseling )
    Goot point kid, if you have a bung carb mount rubber that can also wreack havoc to the idle as well as across the rev range mixture.
    Cheers,
    Grant...
    May 2010
    Perth
    Yeah checked that rubber mount and it's fine, I've one of them bail out on me before so it was one of the first things I checked. As soon as I finish work I'm gonna swap over carbs and see if I can get results, hope to see you all there in the morning.
    Thanks all for your help with this!
