Results 1 to 10 of 11
Thread: rust - structural or cosmetic?
Threaded View
  1. #4
    Perth. WA
    A pillar.
    Welcome Viper green, fantastic colour btw.
    The A pillar is fabricated up from 3 metal stampings spot welded together, If the external corrossion you see has gone into the second inner metal section you will need to open it up to repair the damage to that sheet. Failing to do so does comprimise the rigidity and safety design of the A pillar gives.
    I have some pics here of the way the metal is pressed and welded together on this damned PC somewhere...but can get images if so requested..
    HTH.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
