Results 1 to 8 of 8
Thread: Oil catch can?
    Jan 2009
    south west sydney
    Oil catch can?
    i found an oil catch can in the shed that i bought for my last car that i never used.... how would one intsall on on a stock 1.6 mk1?
    might as well put it to use
    Quote Originally Posted by MiKe1_golf View Post
    Just plumb it straight off your rocker cover breather & mount the the canister where ever you feel the need too!
    Easy as!
    I had just mounted my "powerade" bottle with a breather/filter straight off the clutch cable & plumbed it on with some food processing reinforced hose.
    Worked a treat
    Then relocated the whole lot with a bit more stronger moroso billet bottle & breather. Same type of hosing though
    Oakleigh VIC
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Sunny Coast - The QLD
    Needs to plumb back from the catch can to the air filter on the air intake for it to be legal though.
    MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
    "Fit the gearbox ya bum." Loon - best post ever!
    Jul 2005
    Newcastle, NSW
    I was thinking about adding one on the 16v, but was worried (which may well be unfounded) that it will affect the vacuum readings on the ECU.
    Oakleigh VIC
    Quote Originally Posted by mikinoz View Post
    Only if you vent to atmosphere. Should be OK if you keep it closed circuit.
    Pete
    7? MK1 Caddy
    12 Amarok
    Quote Originally Posted by gotrice View Post
    Not on my car!
    Its pre 6/76! No emission required! hahaha
    I do it on all my cars except for the VN.
    With it plumbed back it can also oil up your intakes & throttles, especially on K-jet cars, so thats why I route it to a catch can & block up the intake so it only gets nice clean filtered air & not filthy oil vapours
    Jan 2009
    south west sydney
    so if you're not plumbing it back you just run from the rocker cover to the can then the can to atmosphere, too easy.
    cant see the pics at the moment due to work blocking photobucket.
