Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: More progress - little steps
    OK I know it's sad, but I finally got to put stuff back ON to the chassis instead of the constant removal mode I have been in for the past year. Only a dry fit so the wheels can go on for its trailer trip to Melbourne, and most of it will have to be removed again when it comes back with it's roll cage... still it felt good!!!
    Note the studdy bits for fast wheel changes and the disk upgrade for better stopability.
    Thanks to Total Traction Services and Canberra VW
    It's been a while...
    Another milestone - trailer the shell from Canberra to Melbourne for John Rawson to do his magic. I told him I didn't want to see it till July at which time it should be sporting a spiffy new roll-cage, some serious chassis plating and strengthening, seat mounts and floor plates (AND NO MORE RUST!!).
    C
    Feb 2006
    Camberwell, Victoria
    Very nice dude!
    I like projects!
    I'll try and get some photos of my uncles mk1 racer to inspire you!!! 1.6L 16v motec m800...
    Maitland, NSW
    the more i see these projects the more i want to learn how to do em!!
    pc's are too easy.. something more difficult please!
    ps: good work btw, lookin good, whats the "magic" next step?
    2.0L 6 Speed Mk3 2015 Skoda Octavia vRS 220 Wagon - Current
    2.0L 6 Speed Mk5 2005 Volkswagen Golf TDi - goneski
    2.0L 5 Speed Mk1 1995 Seat Toledo - goneski
    1.6L 5 Speed Mk2 1990 Golf - goneski
    Quote Originally Posted by Rednut
    Hehe, you assume that I knew what I was doing when I started.... WRONG!!
    I have had fantastic support from Canberra VW and of course the fourums, but basically it started with a $500 mk1 and a desire to build a "nice" older rally car.
    The real danger comes when you start seeing everything as an oportunity to use the sandbaster and apply fresh paint. I have bags and bags of beautifully prepped brackets, braces and misc bits of Golf scattered through the shed. - Sad really....
    Next step is painting - the inside front gets a coat of POR15 then white top-coat. The exterior gets some sanding/priming then more acrylic top-coat. Then I start stuffing bits back in and identifying the gaps (for instance I got webbers and rotary fuel pump and no clue as how I should arange the plumbing )
    C
    BTW The *BEST* finish on any single part of the car so far is (wait for it...) the shaft that runs inside the steering column - something that no one will ever see again
    looks great.. keep us updated!!!! hows the engine build going?
    TassieGTi Guest
    Awesome I really admire the dedication that this project is going to demand of you! It may take a while, but it will sure be worth it in the end Keep us updated with pics, especially the cage when you get the car back in July
    Apart from a G-Grind, twin 40 DOCE webbers, new dizzy/coil, windage tray, cam splash guard and 210mm clutch, the motor is going in more or less untouched.
    I understand from Peter that it was re-built not long ago by Michael (Canberra VW southern branch) and it will do me just fine while I learn how to keep the car (mostly) out of the trees.
    Pete has found me another 1600 to start stripping and building with a few more horses but this will wait till AFTER my first year with the car.
    And before anyone asks, CAMS give lots of freedoms to cars under 1600 (and pre-1986) so I plan on keeping it 8v 1600 (for now....)
    C
    Quote Originally Posted by TassieGTi
    GOING TO DEMAND????? You mean it gets worse?????
    C
    TassieGTi Guest
    Quote Originally Posted by Bluerex
    C
    Looking at it, I'd say there was a bit of work to go
Similar Threads
  1. mk3 dash conversion progress
    By tommymac in forum Mk2 Golf & Jetta
    Last Post: 26-03-2007, 09:56 AM
  2. project KI11Z progress . . .
    By KI11Z in forum Mk3 Golf & Vento
    Last Post: 27-11-2006, 12:45 PM
  3. Rally Golf Progress...
    By Bluerex in forum Mk1 Golf
    Last Post: 18-01-2006, 08:01 AM
  4. progress report.
    By GoLfMan in forum Mk1 Golf
    Last Post: 27-09-2005, 05:07 PM
  5. My Golf- Progress Report
    By el_foolio in forum Mk1 Golf
    Last Post: 30-08-2005, 08:53 PM
