Page 6 of 15 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 141
Thread: MK1 Deisel for the Sh#tbox Rally... a build thread.
  1. #51
    Oct 2013
    ACT
    Congrats. Hope you enjoy driving it around a little bit before the big rally
    Only The Good Die Young 45
    For a better ride, go WIDE!!!
    VS Commodore V6 Berlina- FOR SALE
    1979 Golf Mk1- http://www.vwwatercooled.com.au/foru...one-92128.html
  2. #52
    Orange, NSW
    I have taken delivery from the old man to sort out some small things...
    S13 Silvia fans will like the plates...
    Replaced the 4 inch speakers with fresh ones today, and threw in a LED strip light attached to the interior light to help us with those late night back of 'effing-no-where we need the map moments, I can honestly say the strip light is brighter than the headlights.
  3. #53
    Quote Originally Posted by Jack_It View Post
    Wire in a couple of relays so the power for the lights comes straight from the battery, not via the low beam/high beam switch. Makes a massive difference.
  4. #54
    Orange, NSW
    Always great when your local deisel place has pump parts in stock!
    Gotta sort a leak on the throttle shaft...
    Also, trying to chase ball joints, Tooleys don't have them in stock - anyone have suggestions?
  5. #55
    Oakleigh VIC
    What size ball joints do you need, 15 or 17mm? I might have a couple here.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  6. #56
    Orange, NSW
    17mm I'm pretty sure, also tried Fermans in Sydney and my local guy in on to it too.
    if you have some, that would be awesome. Thanks
  7. #57
    Oakleigh VIC
    I've got a pair here. PM your address details and I'll post them out later today.
    I'm a bit short on the correct 7mm bolts so just drill the holes to 8mm and use high tensile M8 bolts.
    Anything else you're after?
    7? MK1 Caddy
    12 Amarok
  8. #58
    May 2006
    Adelaide South Australia
    Can you post some details [write up] when you fix the leaks?
    Our cow car [banger], needs the spindle seal replaced as well.
    Numerous Mk1 Golf diesels
  9. #59
    Orange, NSW
    Quote Originally Posted by jets View Post
    was going to try, my Mechanic has given me some time in his workshop, so I'll have everything I need and help if it goes pear-shaped.
  10. #60
    Orange, NSW
    It was a day of confusion...
    I took pics, made phone calls, sent messages...
    I'd been given some wishbones with balljoints from MK1@4Motion, and mine needed replacing as the LH side was buggered, Thought I'd do both, as my little bro had finally managed to get them up to me from the ACT... my old man got them and measured the ball joints, telling me they were 17-18mm - perfect, from a Diesel!
    Took out the lower RH to start with, and compared the ball joints, WAT!? they're like 2mm different, crap! I must have 15mm for some reason...
    TXT Preeny, who is adamant that they diesels should have 17mm...
    Do some more digging remembering some paperwork that came with the car...
    AHUH! the Left LCA & Steering rack were replaced after a tow in bingle in 2005... and it was suggested that the struts also be replaced both sides, perhaps that's why...
    I put it all back together and a while later Preeny drops by with a 15mm ball joint in wishbone, I hop to it and pull out the other side which is the actual problem, yep ball joint rooted.
    WHAT! This side is bigger than the one Preeny dropped in!? Break out the cheap ass verniers - Preeny did indeed drop off 15mm ball joints, mine are lo-and-behold, actually 17mm OD, and the ones that MK1@4Motion supplied are nearly 19mm...
    Luckily, after working out all of this the LCA's from MK1@ have already had the original ball joints removed, and replaced with bolt in ones. Peter Jones has sent me some 17mm ball joints, so I'll just swap them over and put in the updated LCAS. and have the original ones as spares.
    PHEW!
