I'm guessing you mean a mk2 2l engine?
Only issue you should have is with wiring, ecu and fueling.
If you want to run the standard mk3 ecu you would have to swap out the fusebox and all the looms. Also if it is a carbied mk1 you will need to run new lines and most likely a new tank.
It will go in on the mk1 mounts though so no fab work is needed but you would need to get it engineered I would think.
Wait for Golf Loon to respond he is up to speed on this stuff and can help you out.
