Results 1 to 10 of 16
Thread: New CV's/driveshafts-availability
    Jul 2009
    Ringwood,Victoria
    Hi again everyone,
    I need to get new driveshafts and was wondering if anyone knows where to get them.
    I had some suspension work done today and on inspection,found the Lhs outer CV is stuffed.
    Tech. reckons that was making the rumble noise on acceleration as mentioned in a previous post.
    A driveshaft business I spoke to says the CV's are unavailable but they will rebuild mine.
    I can't see that working as they can't re-harden the worn contact areas in the housing,just fit new balls (wouldn't we all love that).
    I'd like to renew all the CV's and would prefer exchange driveshafts ready to fit coz that's how I roll-
    don't think,just spend.
    Any advice ?
    Ta. Andy.
    Golf "77 1.6 Auto.
    "That's what she said"
    Jul 2005
    Newcastle, NSW
    You can call Tooley Imports in Hornsby - they are pretty easy to deal with and have heaps of new MK1 stuff available.
    I have in the past bought a large amount in for a few users from the US but you need to pick these parts carefully as the heavy items will catch you out on freight.
    I used http://www.germanautoparts.com/
    Seabrook Vic
    Hi Andy,
    For your drive shafts try Albins offroad gear http://www.albinsgear.com.au/pCompon...om_driveshafts
    they do all custom drive shafts and im sure they will be able to help you with the CV issue aswell.
    Cheers,
    Tony
    P.S Hope to see you on Sunday
    Blow'n Bora
    Jun 2007
    Eastern Suburbs Melbourne
    could get some SH driveshafts off someone (wrecker maybe) and then get new CV's and whack em on.
    You can buy them brand new, I wouldn't bother getting them re-conditioned.
    maybe if you have a few bits and pieces to buy, it'd be worth getting an order from GAP. Last time I checked the dollar was pretty strong against the green back.
    http://www.germanautoparts.com/Volks...bit/Drivetrain
    p.s. make sure you look under rabbit
    i like volkswagens
    Jul 2009
    Ringwood,Victoria
    Have you ordered from them before?
    I've never payed by credit card over the internet,is it safe?
    "enter card details" is usually where I lose my nerve.
    You're right about the prices and the exchange rate,
    both sides driveshafts fitted with all CV's,boots etc.,all brand new Empi brand for $225 + postage.
    Good deal
    Can't wait to see what the postage will be.
    Oakleigh VIC
    Quote Originally Posted by FACT HUNTer View Post
    Good deal
    GAP are great. I've probably spent about $10,000 with them over the last 5 years or so. I've never lost a parcel or had the wrong parts delivered.
    Just e-mail them with any concerns or questions regarding postage, they're really happy to help.
    If you're ordering heavy stuff like driveshafts, be prepared for fairly hefty air mail charges. Also consider topping up the order with all the little bits and pieces like gaskets and shift linkage kits, door handle gaskets etc.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Jan 2006
    Ballarat, Victoria
    I don't understand why you need to replace the driveshafts - please explain.
    You only mention that the CV joints are worn - I would expect CV joints to be readily available.
    Have you spoken with a VW specialist? Boris at VolksCare in Bayswater has been helpful.
    Paul
    Jan 2008
    Surrey Hills, Melbourne
    It's pretty safe. Just make sure the site is secure - the URL should start with https instead of the usual http. But it's dangerous in the sense that you might start ordering all kinds of stuff from the comfort of your computer.
    '76 Mk1 Golf - Gone!
    '05 Mk5 2.0 FSI Sportline
    May 2006
    Adelaide South Australia
    I had a worn CV joint on my Mk1. I bought a S/hand drive shaft from the wreckers [$25 IIRC] on the understanding that if the CV joint was worn it would come back. I dismantled, cleaned & inspected & it was fine. New boot & grease & it's all good. Easy to see once it's dismantled if it's worn.
    Never buy o/seas until you get a quote for postage or freight.
    Germanauto parts want US$31 to post a couple of glowplug relays to me, whereas the 4 glow plugs I bought from another ebay store only cost US $7.80.
    I wouldn't use my credit card details over the internet unless it is Pay-Pal. I would fax all your details.
    Numerous Mk1 Golf diesels
    Jun 2007
    I too was a bit concerned when you said you wanted new driveshafts as well. Unless they're somehow damaged, I'd imagine only the CV's would need doing.
    I only mentioned the new driveshafts so you can do the direct replacement thing. It might be cheaper to get a SH DS from a wrecker and new CV's (from either OS or Local source) and then do that. It's all up to you, but there are plenty of options.
    Like Pete mentioned too, if you do buy from GAP, it's worth while to get a whole bunch of other little bits and pieces while you're there.
    i like volkswagens
