Results 1 to 5 of 5
Thread: Extractors - Worth the Coin?
    Mar 2009
    Hey Guys...when putting the car together i picked up a second hand GTI exhaust with the dual downpipes, although, i'm still running the factory exhaust manifold...however it wasn't in the best condition to start with and I think after doing a couple track days it is starting to bite the bullet...
    I guess what I'm wondering is if I'm going to replace the exhaust, are extractors worth buying? Can I expect any real improvements or noticeable differences in performance or fuel consumption?
    Michael.
    78 2-door 1.8 KR 16v - twin dellorto's
    Jun 2006
    Orange NSW
    If you want to go further with a bigger cam etc, yes.
    They make bugger all difference on a standard engine. But you're running decent carbies etc, so they will help a bit. Don't expect a 35hp increase or anything, though..
    An engine is just an air pump. You put on bigger carbies to get more air in, you work the engine to get as much air through it as fast as possible and you fit a free flowing exhaust to let the air get out faster. A 4 into 1 exhaust is the most efficient but those efficiencies are more noticable at high rpm. A 4 into 2 into 1 exhaust gives better torque down lower in the rev range. If you use your car mostly at high revs then go for the 4 into 1. For normal road use go with a 4 into 2 into 1.
    Sydney NSW
    Hi mate , I have a set of used extractors in good condition for an 8v
    I could swing them to you for $100
    Mar 2009
    pm'd.........
