Results 1 to 10 of 13
Thread: Drill 25mm LHS front guard hole for aerial - How to?
    Oct 2006
    Albany Creek Brisbane
    Hi All
    I have to drill a 25mm hole in the LHS front guard to fit an aerial, what is the best way to do this as the largest drill bit I have is only 10mm wide...
    Any ideas?
    Aug 2006
    Melbourne VIC
    Ahhhhh dont cut a hole in a mint Mk1 guard.
    But if you do have to... Get a 25mm hole saw bit.
    Oakleigh VIC
    With a hole saw
    or a punch
    or perhaps a step drill
    they're probably the more common ways to do it.
    Personally I'd go without the radio rather than cutting the guard.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Adelaide hills, SA
    You could use Dremel, if you have one.
    Aug 2009
    Use one of the aerials you stick to the inside of your windscreen.
    Glass Window Windscreen Mount Car Radio Aerial Antenna (eBay item 170595315956 end time 25-Feb-11 14:53:31 AEDST) : Cars, Bikes, Boats
    Or do what I do and serenade yourself.
    Oct 2006
    Thanks guys!
    Do I have to keep the paint/ metal cool if I do drill the guard so the paint does not blister from heat or something? What do I use? Water??
    May investigate other alternatives however I don't mind the aerial on the guard looks like it should be there IMO..
    Oakleigh VIC
    Just drill slowly. Cover the area in masking tape for a fair distance around the cut and drill through the tape.
    This will help minimise damage from hot metal off the drill burning pits into the surrounding paint.
    Best to protect the bonnet and windscreen too.
    Remember to paint the freshly cut steel so it doesn't rust.
    7? MK1 Caddy
    12 Amarok
    Jul 2010
    NE NSW
    Garbon,
    save yourself some grief, and get a panel beater todo it for you.
    Steve
    Jun 2008
    Melbourne Aspendale
    If u are going to Go the hole saw route I've just had to drill through some 44 gallon drums for a bio diesel project. I took it nice an slowly. And use and oil lubricants to keep the saw bit clean and cool. It was a fairly clean cut but it will take off paint around the area. For the drums it was ok but I don't think I would do it to a car panel.
    Mark
    1980 GLD
    1979 300D Mercedes
    1980 300TD Mercedes
    1956 Desoto Panel Van... Maybe to comeback to life as a diesel???
    Adelaide hills, SA
    and put some masking tape around the area to minimize scratches.
