I use the same ones they run in 20VT's, just what my VW mechanic gave me..
They're 4 prong ones.
Just wondering what plugs people run
Atm i Got NGK ones, BP6EY? i think
Engine is a 1.8L stock, with extractors and 2" exhaust
Checking the plugs against the guide in the Haynes manual it says my Plug is Overheating due to either Low Octane Fuel, Ignition timing, or weak fuel mixture. Tip is a Light brown colour, and some of the white bit in center is light brown and white.
Carby is a stock 1.6L one and ran fine on the 1.6L. is going to a 1.8L making it run lean? going to double check timing when i get hold of a light, and will fill up with a fresh tank of Unleaded. (surely it wouldn't need premium?)
Any tips be great![]()
<space for rent>
I have had problems with "high end" multi pronged spark plugs in the past. I never had any broblem with the standard single prong bosch ones that are listed in the book at supercheap.
i think its something like WDxx7 orsomething, haha.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
We ended up getting some 3 prong KGL or KLG plugs from supercheap, it was like $10 for a set of 4 (this $$ figure may not be 100% correct as this was a while ago, but its heaps less than the big name plugs).
i just got them to get the car running correctly. they have been great plugs and i would def recommend them and will get them again when i need plugs.
If you want the model number i can check tonight.
~~~~____~~~~~~~~~_\_____
~~~ /_|__\__~~~~~~ / //__|__\___
____( )|__( ) ]_MKI ___[(' )__|___( ) ]_MKIV__
I've used the bosch ones (listed in the book at supercheap etc) without trouble before as well. I just use the 4 prong ones now.
Awesome, ill grab a set, and a new coil and install them along with the new points. should be good then![]()
<space for rent>
Going by that,
Bosch W7DC is same as NGK BP6EY
<space for rent>
single prong ones are fine for an 8v. Multiprong can be an overkill and do more harm than good.
