Results 1 to 5 of 5
Thread: 4 speed & 5 speed shifter bushings. Same or different?
    Mar 2010
    brissy
    Hey all,
    I want to replace the sloppy bushes out of my mk1, but have a question regarding to the shifter bushings. It's got a 5 speed box from a mk2 GTI in it. If i was to order bushes, should i do so according to the model of the car the box came out of? Or true to the chassis?
    2011 TDI Caddy- AirRex x AccuAir setup.
    Gosford Central Coast NSW
    depends on if you have a proper 5 speed linkage setup or a modified 4 speed setup.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Oakleigh VIC
    Bushes are the same.
    Selector rods and transfer lever are different , there's 4 speed ones and 5 speed ones.
    The 4 speed selector rods have white ends and the 5 speed ones have black ends.
    The ball on the end of the transfer lever is a smaller diameter on a 4 speed.
    Take a look at the offerings on GAP.
    GermanAutoParts.com
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Mar 2010
    brissy
    Thanks for the info Peter; in summary, any bush kits for the MK1 will work.
    Oakleigh VIC
    Some kits come with the selector rods and transfer lever. You need to specify 4 or 5 speed for those kits.
    Kits that are bushes only suit either 4 or 5 speed boxes.
    7? MK1 Caddy
    12 Amarok
