What's Making This Noise?
Quote:
Originally Posted by
Hail22
How did you go with asking the dealer about the your noise concerns?
It's stopped making the noise so we haven't bothered (not that we've had any time). The next service is booked in for next Friday and I'll ask them about it then.
I think maybe it was doing a DPF regeneration and it tends to make crappy noises when it does – it's just never sounded quite as bad.
Just a quick update on this:
The car is booked in for this Friday for a service and some warranty issues including:
- Engine noise
- Engine stalls when active regeneration of the DPF is occurring while in neutral (coasting up to an intersection) leading to a loss of power steering and assisted brakes.
- Vacuum hoses need to be replaced
- Passenger side rear door seal is cracked and needs replacing
- Luggage compartment light does not work
The car isn't going to be driven until the service just in case something goes wrong on the road and we've borrowed a friend's Alfa Romeo Brera until it's fixed.
Alex.
Ok, 879 dollars later, the 60,000 km service was done today.
They fixed the vacuum hoses and door seal, gave it a good clean inside and out and had a look at the issues we asked them about.
For the rough running and stalling while in neutral, they did exactly what I thought they'd do: "Completed scan of the electrical systems to reveal no codes in the systems; Road tested the vehicle to reveal no abnormal operation of the vehicle; Recommend at least replacing the engine air filter"
Yeah, thanks for fixing that VW
For the boot light not working, they said: "Tested the boot light to confirm the issue, adjusted the contacts of the bulb holder to rectify the issue; Customer monitor the concern and contact the service dept if concern arises again in the future"
Got home (mum didn't check at the dealership because she was late to an appointment) and opened the boot, guess what? IT STILL DOESN'T WORK!! They had the car from 8:00 AM to 4:30 PM and they obviously didn't even bother to check if their 'fix' had worked. Thanks again, VW!
They also recommended replacing the windscreen wipers (which are working absolutely perfectly) for 83 dollars, replacing the tyres, and replacing the air filter for 61 dollars. Oh, and the rear brake pads – 224 dollars (we won't get them done at VW)
Other than that, the standard 60,000 km stuff like brake fluid and fuel filter etc.
We will be going back on Saturday to let them know about the boot light still not working.
Edit: updated to correct price
gavs
Berwick VW by chance?
Indeed, yes.
