Results 1 to 6 of 6
Thread: Are the Side Mirrors able to be programmed via VAGCOM when engaging Reverse?
    AutoBahn
    Just wondering guys if possibly the polo has the coding system/VAGCOM to be able to program the side mirrors when engaging reverse to angle down so you can see the kerb (preventing guttering but also accuracy in tight streets to prevent hassle).
    Nov 2009
    Dana from RossTech provided me with a few codes to check/try but haven't tried anything yet. I've been sending him debug logs and the control map scans as they don't have a lot of info on the Polo/ECU.
    I'm not really game to experiment with the missus car so I'm holding off until more info is available.
    FYI: (hope its ok to quote Dana's email...)
    Quote Originally Posted by Dana Smetanick;
    I see a few bits that are related to comfort and rain closing. I've taken this original coding and tweaked a few things:
    24B02BBF08A1000001380000742B0ED000C0410F6084000020 0000000000
    1st) Comfort close roof enabled - Byte 3:
    24B02BFF08A1000001380000742B0ED000C0410F6084000020 0000000000
    2nd) Rain Closing Enabled - Byte 4:
    24B02BFF0AA1000001380000742B0ED000C0410F6084000020 0000000000
    3rd) Rain sensor active (That one is odd) - Byte 14:
    24B02BFF0AA1000001380000742B4ED000C0410F6084000020 0000000000
    I'm not so sure about the actual RLS itself:
    Part No: 1K0 955 559 AH
    Component: RLS 170510 05 54 0403
    Coding: 03302D
    On the Golf/Jetta Rain Closing active is Byte 0, Bit 2. Please try recoding the RLS (slave from 09) to: 07302D
    Feb 2010
    Did anyone try this?
    2020 VW Golf R
    Nov 2009
    I haven't tried coding anything with either car yet as I haven't had much time other than run the debug results for Ross-Tech. Hoping to have some time to play around over the xmas break.
    Adelaide hills, SA
    It works with memory seats option in 2008 Touareg.
    Jan 2011
    Bumpage.
    Any progress on this?
    I'll need to do some Vagcom work when I install the bluetooth and MDI, so would like to activate this too.
    2010 Polo GTI - 5dr Flash Red
    Completed upgrades: RNS 510 install, Retrofit MDI, Bluetooth
    Planned upgrades: Amp, 3 way speaker install
    Planned mods: APR tune, Brembo brake upgrade
