Results 1 to 4 of 4
Thread: Problem of audio upgrade
    Jun 2011
    Maroubra, NSW
    Hi there,
    i am currently having a vw trendline(cant wait that long for a tsi) and which come with RCD310. I found RCD510 which from china is around $100, but i have google for the information about install..but still have some confuse?
    -What is CANBUS for?
    -Is that the trendline cant install the MDI as well?
    -Other than the RCD510, what do i still need to buy for the installation?
    -Need any modify for the steeling wheel control? (volume,next song etc.)
    Thanks for answering my question..
    Oct 2010
    Melbourne, VIC
    CANBUS controls almost all the electricals and electronics in recent VWs
    I don't see why the Trendline can't have the MDI installed unless there is a space issue for the connector unit thingy.
    The RCD-510 is all you need (apart from a butterknife/spatula to pop off the surrounding trim and a T20 torx bit to undo and redo the screws holding the unit in)
    If your Polo can control the RCD-310 through the steering wheel, then it will also word work with the RCD-510
    $100 is incredibly cheap
    Jan 2011
    $100 is very cheap. Well done.
    Perhaps others on the forum may like to upgrade. Care to share?
    Re: install
    You could follow my write up on the nav system, it's the same process
    2010 Polo GTI - 5dr Flash Red
    Completed upgrades: RNS 510 install, Retrofit MDI, Bluetooth
    Planned upgrades: Amp, 3 way speaker install
    Planned mods: APR tune, Brembo brake upgrade
    Jun 2011
    Maroubra, NSW
    Sure for share.
    The RCD510 i found is from china(chinese website)
    the unit is brand new($75) with the shipment to aus is $25..so total is 100..
    and they have hundred of 510 in stocks..
    just let me know if anyone is interested..i can help with the chinese website..
