I'm not sure you have much of a choice, Scott.
Given it will be "fixed" under warranty, the dealer will likely confer with VAG and together they will decide on the course of action.
It seems that the first thing they try is a piston ring replacement.
The only thing you can do, as far as I'm aware, is keep an eye on it after each attempt to rectify the problem.
